thrust for showtime 90
anybody have to change the thrust angle on the showtime????? Mine will climb when I cut throttle so I added up thrust but have yet to fly it.Just wondering if anyone has had similar issues.Im using the YS 110
RE: thrust for showtime 90
G'day Mate,
Are you sure it is a thrust problem, there could be a CG problem, Eg. too far forward. Check out this trim chart, it may help. http://www.palosrc.com/instructors/trim-chrt.htm Did you do your throttle down test from full throttle, trimmed straight & level, then chop power, if not, it may not mean what you think it means when it climbs. |
