paints for planes (balsa)
Being in an area where hobby supplies are almost non existant can any one advise me on what paint to use on a balsa sheet model plane ? Availability are acrylic paints (water soluble ) commercial spray paints etc would acrylic work with a plane using a glow engine ie fuel spill, exhaust etc. Any help greatly appreciated.
RE: paints for planes (balsa)
I assume you are fiberglassing, and not trying to paint directly on the balsa wood, right? As far as fuel proof paints, nearly any 2 part automotive paint will handle it, as well as the Lusterkote series from Top-Flite. Some of the solid rustoleum colors are also glow fuel proof.
Latex paints are fine for glow planes WITH THE FOLLOWING CAVEATS:
1. The paint MUST be clear coated. 2. The latex must "cure" for a MINIMUM of 10 days before clearcoating. 3. Use a fuel proof clearcoating such as Lustercrap clear or Ultracote clear. Water base polyurethane is FUEL RESISTANT (Minwax Polycrylic ). If you use a water base poly let the poly dry for a MINIMUM of 7 days before exposing to fuel residue and do not let the residue remain on the finish for longer than 4 hours. At about 4 hours the poly begins to soften up. If you decide to use an ACRYLIC CLEAR ENAMEL for clear coating do a test panel FIRST. Check the clear coat for raw fuel resistance, then expose it to the exhaust of a running engine for several minutes, let it sit for a few hours, THEN clean it. You will know right away if it is fuel proof. SOME of the Rustoleum paints are fuel proof, however I am not sure which ones. The MAJORITY of ACRYLIC automotive enamels (spray cans) are fuel proof, HOWEVER DO A TEST PANEL FIRST. |
