RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Smoking Fluid (https://www.rcuniverse.com/forum/questions-answers-154/5694148-smoking-fluid.html)
musalami 04-10-2007 12:18 PM
Smoking Fluid
Greetings,
What is the best "do it your self" smoking fluid?
I am using pure diesel; is there any thing I can add to it to make a better smoking fluid?
Is there a way to make a colored smoke?
Thank you all
The Ghost 04-10-2007 04:55 PM
RE: Smoking Fluid
try a 50/50 mix of diesel and auto trans fluid. All other mix's is just trial and error. There are many other oils and fuel mixes that will work. it's just a matter of what you can get and try. Smoke oil mixes are very guarded and you will have a hard time getting the mix ratio and type of ingreadents.
Cheers
musalami 04-12-2007 02:50 AM
RE: Smoking Fluid
Thank you very much, that is a great help.
Any idea how to make colored smoke?
MinnFlyer 04-13-2007 05:51 AM
RE: Smoking Fluid
Nope, white is all you'll get unless you go with the type of smoke bombs that burn
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
