RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   In cowl muffler build problem? (https://www.rcuniverse.com/forum/questions-answers-154/582605-cowl-muffler-build-problem.html)
v6goose 02-25-2003 10:21 AM
1 Attachment(s)
Hi Guys... :)
Im building a Kyosho F4U ARF, and have a problem fitting an in cowl (my build) into my model.
I used a commercial header and pitts style can muffler in my TF P51 that works a treat. Unfortunately there is no room in my F4U as per the attached drawing.
Has anyone done this? All your idea's and comments are appreciated.
Key to the drawing...
  • Cyan - Glass firewall of F4U.
  • Red - Glass filled motor mounts.
  • White - ASP 61 Aii engine.
  • Magenta - Self made header.
  • Yellow - Cowl mounting ring (Plywood).
  • Green - First cut at a muffler outline.
  • Dark Blue - Cowl extremity.
Cheers!
Goose
MinnFlyer 02-25-2003 05:21 PM
I don't think I completely understand. Does the exhaust HAVE to exit the bottom center? Can't you just move the muffler over to where the engines header is?
bignasdy-RCU 02-25-2003 07:50 PM
looks to me you could just turn that muffler around and conect to the header
d
v6goose 02-26-2003 02:09 AM
Thanks for your replies Guys...
Im used to building headers and exhaust systems for larger aircraft, so this little F4U was a bit of a challenge.
I have opted to bite the bullet and spend $$ on a J-Tec pitts style muffler, connected directly to the exhaust of the .61.
Cheers...
Goose
MinnFlyer 02-26-2003 04:34 PM
Well, that was easy....
Let's go get a beer.
v6goose 02-26-2003 08:24 PM
MinnFlyer...
What a great idea!
Make mine a 'Jack'... :)
Cheers
Goose
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
