RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   retracts (https://www.rcuniverse.com/forum/questions-answers-154/5874221-retracts.html)
phillyfry 05-19-2007 10:54 AM
retracts
hi guys, i have a new hanger 9 t-34 and would like to put a set of robart retracts in her. the radio system iam using is a futaba t6exa. this bird calls for a nose gear retract . i have several bird with retracts on the mains ,but this will be the first with two servos mains and nose gear. how do i hook up the nose gear servro with the mains. never did this before.i only have one ch.(5) to do it with. help needed thanks much.
mscic-RCU 05-19-2007 11:27 AM
RE: retracts
y connector
phillyfry 05-19-2007 06:14 PM
RE: retracts
i understand a y con. for the two main servos but you still have a 3rd one out there that needs to be hooked up...
Campy 05-19-2007 06:24 PM
RE: retracts
2 Y connectors. from the one leg of the 1st Y hook in the 2nd Y
aerowoof 05-19-2007 07:24 PM
RE: retracts
go with air operated and then one servo will be needed.
Steve Collins 05-21-2007 08:37 AM
RE: retracts
Air retracts are far less "fiddly" anyway. I second the suggestion to go with Robart air retracts.
2slow2matter 05-21-2007 09:26 AM
RE: retracts
The plans call for a retract servo for each main? So three retract servos? That is WAY overkill.
Airs would be best. Then all you would need is one MICRO servo.
MinnFlyer 05-21-2007 10:14 AM
RE: retracts
Sorry, I disagree.
I tried Air retracts back in the 70's and hated them for various reasons. I became a "Mechanical Only" guy.
I am now reviewing the Top Flite Cessna 310 which came with Robart Air retracts. I will admit that air retracts have come a long way, and the Robarts are excellent units, But I can't tell you how many times I wished they were mechanicals.
My advise: Use 2 Y cords and don't even THINK about Pnumatics.
j.duncker 05-21-2007 03:39 PM
RE: retracts
1 Attachment(s)
Air is the way to go now. Lighter and less complicated. Running retract servos off the main airborne pack runs the risk of a stalled servo running the pack flat in flight. OK you can have a subsiduary pack but more weight and light modles fly better.
Air up spring down is failsafe. Use these quick connectors and incorporate a restrictor in the airline so they do not bang up and down.
These are Robart and they work well.
