2-56 threaded rod
Where can I get some 2-56 threaded rod that’s all tread? Most I’ve seen is just threaded on the end.
RE: 2-56 threaded rod
DuBro, which usually means your LHS will carry it if they are worth anything at all.
Dubro only sell it in 12" lengths. The only other #2-56 rod I've found is from McMaster-Carr and it is also 24" maximum. I found some stainless steel machine threaded, still 24" at Smallparts.com
I think there are two reasons for the short length. If you look at the all thread section in the hardware store, most of the small rods look a lot like pretzles. Shipping and storage without damage is a problem. The other reason is that there really isn't a practical application for threaded rods that small and of that length. If you want threads on both ends, you are going to be limited to either using a solder coupling or solder on threaded end, or welding two end threaded rods end to end. You are not likely to get a usable pushrod doing that. I personally like the solder on threaded ends. It is easy to gage the final length and it gives a clean and strong joint. Don |
ORIGINAL: John Palica DuBro, which usually means your LHS will carry it if they are worth anything at all. |
The model railroaders use this quite often. Need to visit a place that specializes in such. Not a airplace place either.
Wm. |
ORIGINAL: Gstan ORIGINAL: John Palica DuBro, which usually means your LHS will carry it if they are worth anything at all. Great Planes version: http://www2.towerhobbies.com/cgi-bin...?&I=LXK062&P=0 And Sullivan: http://www2.towerhobbies.com/cgi-bin...?&I=LXFV06&P=0 |
ORIGINAL: piper_chuck ORIGINAL: Gstan ORIGINAL: John Palica DuBro, which usually means your LHS will carry it if they are worth anything at all. Dubro 12" full threaded 2-56 rod: http://www2.towerhobbies.com/cgi-bin...?&I=LXD868&P=0 Great Planes version: http://www2.towerhobbies.com/cgi-bin...?&I=LXK062&P=0 And Sullivan: http://www2.towerhobbies.com/cgi-bin...?&I=LXFV06&P=0 |
What is it you want exactly? How long a piece of continiously threaded rod do you want.
Ed S |
ORIGINAL: Ed Smith What is it you want exactly? How long a piece of continiously threaded rod do you want. Ed S 12” is fine. I found it on tower thanks to Piper chuck |
