Any ideas
Anyone have any good ideas to remove glue from fabric. Just startrd covering my piper cub, and was gluing the control surfaces together, and sure enough, I got some on the covering.
RE: Any ideas
What kind of glue---if ca use the ca debonder soak and wipe away with paper towel. If epoxy use a heat gun to soften be very careful not to heat covering too much then peel it off--if white glue a little water and towel.
RE: Any ideas
I've had good luck with trim solvent. I don't care if its a minute or the next day, it seems to work ........... Greg
