Dual tank, 1 engine - How to?
I am faced with an interesting problem, and hope someone here can help. I have tried searching RCU, but have not found the details I need, so my appologies if this has been recently covered.
Due to space limitations on my current (custom) project, I am considering using dual tanks. One would be close to the engine, and the other near the CG. The engine is a converted WeedEaterŪ gasoline engine without muffler pressure, but I'm told it has a pump. How exactly are the fuel lines hooked up to ensure a good fuel supply? I could use one long, skinny tank as well, but I am concerned the clunk will suck air while in a dive. Also, if I want only one tank, I have to make my own, since I can't find a comercially made tank which will fit (I want 16oz or more). Thanks in advance for any help (epecially illustrations). |
1 Attachment(s)
Plug the feed from the rear tank into the vent on the front tank. A gasser will pull the fuel.
Thanks MinnFlyer, that'll be easier than trying to make my own tank. I can get 2 - 8oz tanks in that way no problems.
How do I run the vent of the second tank so that it doesn't spill during manouvers? |
Originally posted by strato911 How do I run the vent of the second tank so that it doesn't spill during manouvers? I've often been told to place a Perry check valve allowing flow to go only into the tank. But in an inverted run, more foaming seems to occur. So I am also interested if there are other solutions to this. _____________________________________ Max Throttle Departure Recovery: Stretching the space and time in the brief seconds before a crash. |
Stacking Tanks
Dennis
I have successfully stacked up to three tanks for a .45 powered X-country airplane. In that case: 12oz in the nose, 14oz in the radio compartment and 24 oz above the wing on the CG. I did use an oscillating pump because of almost eight inch change in head level between the tanks. Your carb pump like Minn Flyer says should be plenty. And the hook up is exactly like his drawing. It would be my suggestion to take a hint from the Ukie guys and loop the vent of the rear tank upward then down and forward and direct it straight into the prop flow. Leakage will be minimal. John :) |
Can a gas engine use muffler pressure?
In theory it should be possible, but I sure don't want to see what happens if the exhaust still has a slight flame :stupid: . An old lawnmower my dad had used to shoot a flame out the muffler 6 inches when the engine got hot and misfired...
If this happens on a plane using muffler pressure - BOOM!! Don't worry about landing it. :D |
Hmmm... maybe I can talk one of my fellow club members into doing it then. I'll leave the "boom" part out of the conversation though. :)
Originally posted by strato911 How do I run the vent of the second tank so that it doesn't spill during manouvers? And NEVER use muffler pressure on a gasser! Like Strato said "BOOM" |
MinnFlyer,
I would like to use that picture in my tips section |
You (and anyone else) may use any of my pics for a not-for-profit use. All we ask is that you credit RCU for the pic. Thanks :)
Originally posted by MinnFlyer You (and anyone else) may use any of my pics for a not-for-profit use. All we ask is that you credit RCU for the pic. Thanks :) |
