Calculating CG
I recently aquired a small BIPE already built. It is quite old. I have no idea what plane it is and I have no manual.
1. Am I correct that the CG is generally 1/3 of the wing Chord? If not what is the general rule. 2. Top wing is slightly more foward than the Lower wing. Which wing do I use for setting CG? Need help. Thanks Lou |
Calculating CG
