Saito 100 4/s
My Bad..I moved the lower end setting on my Saito.Can ya'll please tell me the proper way to set the lower end..?? Is it screw all the way out then screw in X number of times,or is it just the opposite..?? Please tell my how to get it back ( close ) to factory settings.
Thanky... Pappy |
RE: Saito 100 4/s
Here`s a link for setting the ls needle on both plastic and metal throttle arms.[link=http://saito-engines.info/new_engine_prep__.html]Saito Info[/link]
RE: Saito 100 4/s
Set it just( 1/16") below the plastic control arm. If you are trying to remove the arm, there is a setscrew you have to loosen.
RE: Saito 100 4/s
MANY MANY THANKS YOU GUY'S............................INSANEMOONDOGGIE THE SITE WAS JUST WHAT I WAS LOOKING FOR
PAPPY |
