RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   which battery is better? (https://www.rcuniverse.com/forum/questions-answers-154/6325286-battery-better.html)
edith228 09-04-2007 05:19 AM
Hi mate,
I own my 6CH helicopter AFT kit E017D.
I want to update the battery.
The original battery of E017A is EK1-0180.
Wanna to ask:Is it ok change to this RC Pro X Li-Polymer Battery 11.1V 10C/18C 2200mAh?
Detail is:http://www.rc-spareparts.com/rc-pro-...-p-1496.html:D
Or you have other suggestions?;)
jetmech05 09-04-2007 06:06 AM
RE: which battery is better?
I'm not much on electric systems for your application,,,but if the voltage is the same..the polarity is the same.then its good to go..the MAH rating just gives you an idea on the life of the battery depending on load. ie 2200mah you can draw 2200ma for an hour or 1ma for 2200 hours. hope I helped you out
