Moki 360 Twin
Hi folks out there. I need some help to locate some replacement parts for my Moki 360 which broke the crank pin while I was running it in.
No its not covered under warranty as it is an "old" but new motor. Parts required are front crank with the 10mm crank pin, front con rod, front crankcase (relieved for the bigger bottom end con rod) and the intermediate disc. Any suggestions and help on this would be much appreciated. Thanks rjmods |
RE: Moki 360 Twin
Try Mark's. They are now the importer for Moki in the USA. I used to race a 3.6, and I would burn out the cranks with great regularity. I even had one converted to ignition, and had a pair of nice tuned pipes on it. Something about pulling a 20X12 prop that they don't like. It was fast as all get out though (while it lasted)
Bill, AMA 4720 WACO Brotherhood #1 |
RE: Moki 360 Twin
You might try contacting Brian Winch. He is an Aussie, and should be able to rebuild your crank, or might even have one on hand. Or he might at least know where to get one.
Bill, AMa 4720 WACO Brotherhood #1 |
RE: Moki 360 Twin
Stickbuilder do you have a contact point for Mark's like web site, email or even phone.
Thanks rjmods |
RE: Moki 360 Twin
No, but I'll see what I can find and post it for you.
RE: Moki 360 Twin
Thanks, heading off to bed now, have to work in the morning will check then
rjmods |
RE: Moki 360 Twin
Your Australian dealer is:
Tates Toys 135 Shannon Ave. Geelong West Victoria, Australia 3218 phone: 61 352 224201 fax: 61 352 231257 www.tates.com.au |
RE: Moki 360 Twin
I have found out that Marks still offers the 3.6 twin. Parts should not be a problem.
