OS 46 AX engine mounts
Gidday. Can anyone tell if if the mounting holes for a OS LA 46 are the same as the OS 46 AX. Thanks Glenn
RE: OS 46 AX engine mounts
I think so I changed to a 46 from a 40 years back. I don't remember having to change mounts....go to OS web set they give dimensions...
Good idea. Thanks
thier the same
Go check Tower hobbies specs on the two engines.
Seems the specs differ for the mounting holes. 1.6" versus 1.7" Probably close enough, but............. Tower has this detail info on about anything. It's a good place to answer questions like this. |
