Transmitter Case
Now that i have my field box,I need a case for my Futaba 9c.Does anyone have any suggestions.I would like something just big enough for 1 Transmitter with cushioning around it of course. I saw a plastic case at the Hobby shop for $5.00 but i think i would like something a little nicer.This Transmitter is nice! and i would like to keep it that way
THANKS. BARZINI |
Transmitter Case
Go to Home Depo, Lowes, Menards and look for the aluminum tool box. They're about $20 and come with perforated foam so you can easily make the foam fit your xmitter.
http://www.********.net/forums/showt...&threadid=4061 |
Transmitter Case
go to Wal-Mart and get a pistol carring case big enugh for 2 raidos
Transmitter Case
Our Wal-Mart doesn't carry pistol cases and I didn't feel like driving the hour to Home Depot. I did find a nice pistol case at Cabelas for less than ten bucks. Lots of foam and big enough for two transmitters. Works well for me.
Tx case
Get pistol case, they are cheap and work very well.
John |
TX Cases
The pistol cases I have used are plastic.
Sam's and Wal-Mart usually have an aluminum tool/instrument case for $20-$25 that is the same as the JR or Futaba cases less the name painted on the top. Mine holds 2 transmitters, tach, digital camera, glow starter easily. |
Transmitter Case
Wal-Mart considers the pistol case a seasonal item.
Check during hunting season. |
Transmitter Case
You could try one of these:-
http://www.hobbypeople.net/gallery/237600.asp - fairly expensive, but really good. There are two versions - single and double size. -David C. |
Transmitter Case
If you have a Harbor freight close by they frequently have this one on sale at the cost of $14.00.
The inters are removable the tool holder on the lid can be removed, used to store props, hanging on the wall. You can use foam rubber for cushioning Tool Case |
