RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Rossi .53 engine (https://www.rcuniverse.com/forum/questions-answers-154/648961-rossi-53-engine.html)
RBacio 03-26-2003 01:22 AM
Rossi .53 engine
I'm looking for a strong motor for a 40 size Ultra Stick. I want to be able to fit it into the stock motor mount so I won't have to re-drill holes and relocate the already installed anchor nuts. I'd rather not shell out a fortune and go 4 stroke. Does anyone have any experience with the Rossi .53?
rc-sport 03-26-2003 03:40 AM
Rossi .53 engine
RBacio, I don't no anything about Rossi engines but I had to reply because your name is really close to mine. Take off the O and add a C and thats my name. Thought you'd like to know.
William Robison 03-26-2003 04:06 AM
Rossi .53 engine
RBacio:
Generally speaking, the Rossi engines are very powerful, but have to turn high rpm to do it. And they are mostly heavier than other engines of the same displacement.
In other words, the Rossi 53 will drag your 40 stick, if propped right, out of sight in a heartbeat. But vertical? You might not like it. The Rossi just wants to go fast.
If you already have the Rossi, bolt it on and go. But on the Stick I think you'll be happier with a lighter engine.
Bill.
RBacio 03-27-2003 01:41 AM
Rossi .53 engine
High revs, low torque. Got it! Thanks
bugsiegel 03-31-2003 03:08 AM
os
I hear the os. 50 is a strong engine in comparison to the 46.
funflyer99 04-02-2003 06:14 AM
rossi
Rossi 53 will not fit into an engine mount for a 40 like the OS or TT. Even a Rossi 40 won't fit, they have a larger case. The Rossi 40, 45, and 53 have the same size case.
Todd.
RBacio 04-03-2003 12:27 AM
Rossi .53 engine
I don't think that it is a standard .46 size mount. The Mfg.'s instructions say that the mount will accept up to a .58, besides you guys have already talked me out of the Rossi. I have already opted to go with the OS.50SX.
Thanks for your guidance
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
