Perry pump with flat twin?
Can I use a Perry pump ( the one that works with engine vibration) with a Saito 100T flat twin? I imagine the vibration with this engine will be less than a single cylinder engine, so will the Perry work and how should it be mounted? Would another type of pump be better?
RE: Perry pump with flat twin?
goatbasket, I use a VP-20 (vibratory) with my O.S. 1.60 flat twin. It works fine. The mounting instructions are included with the pump.
| All times are GMT -8. The time now is 04:42 PM. |
