Pressure Sensitive Trim
I have used the pressure sensitive Monokote trim with great success when applying to Monokote but will it also stick well to balsa?
RE: Pressure Sensitive Trim
For anyone else wondering about this the answer from TopFlite follows
SNIP The adhesive backed trim sheets would work on balsa, too. Just like Monokote the balsa needs to be clean of any dust or other debris that would prevent proper adhesion of the trim sheet. |
| All times are GMT -8. The time now is 11:22 PM. |
