RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Prop Question? (https://www.rcuniverse.com/forum/questions-answers-154/69632-prop-question.html)
PLANEIAC 03-05-2002 07:04 PM
Prop Question?
Can someone tell me the difference between a 18x6 and a
18x6-10 prop?
sk
hiroboz 03-05-2002 09:35 PM
prop markings
Advanced Swept-Tip Design Reduces Vortices at the Tips for Quieter more Efficient Performance.
18x6-10 means the pitch varies from 6 to 10 degrees
hope that helps
:D :D :D
raskco 03-09-2002 03:10 AM
Prop Question?
18x6 - 10 only means that you can use a 18x6 all the way to 18x10 prop... so like 18x6 or 18x8 or 18x9 or 18x10
In other words if you use a prop that's more pitch then "10"
Your probably over proped...
The 18 means 18 inches and the other number means the pitch of the prop ok.. L8ER
Dazzler 03-09-2002 04:03 AM
Prop Question?
Rasko, I believe what they are talking about is a prop that is actually called a 18x6-10, its all in one prop. It is as hiroboz said!!!Daz...
winship 03-19-2002 03:04 PM
Prop Question?
PLANEIAC;
18x6 prop is a constant pitch prop meaning that the pitch of the blade is 6".
18x6-10 prop has a progressive pitch meaning that it is 6" at the hub progressing to 10 inches at the tip.
Ever notice how an APC prop blade has a hump on the top of blade at the hub area? This is to get the constant pitch. Even though the APC blades are constant pitch there is more of an angle at the hub for the same pitch. I have a large pitch guage that can be seen on http://winshiprc.tripod.com Go to the props page to see it.
raskco 03-19-2002 05:36 PM
Prop Question?
MMM I thought different... on prop that they recomemded for the one plane I was working on was a 16-6 -10 I thought it was from a 16-6 to a 16 -10
MMMMM I'll go look at the chart.... Wanna find more out about this....
STUKA BARRY 03-24-2002 03:48 AM
Prop Question?
VARIABLE PITCH PROPS ARE GENERALLY USED ON COWLED AIRCRAFT. A 16X6-10 SOUNDS LIKE A ZENOAH G-23 OR COMPARABLE SIZE ENGINE. THIS SIZE PROP WOULD WORK JUST FINE ON A 1/5 SCALE WACO. WITH A BIG RADIAL COWL, THE 6 PITCH PASSES BY THE COWL OUTWARD AND GRADUALLY INCREASES TO 10 PITCH AT THE TIP. THIS IS A VERY EFFICIENT PROP FOR THIS CONFIGURATION. HENSE THE 16X6-10 PROP. THIS EFFECT IS MINIMAL ON 60 SIZE AIRCRAFT. YOU GENERALLY WONT FIND MULTIPITCH PROPS IN 14 INCH AND SMALLER.
PLANEIAC 03-24-2002 02:08 PM
Prop Question?
Thanks for the explanation.
I was talking about the 18x6-10 single prop not the
18x6~10 meaning 18x6,18x7,18x8 ect. instruction manual prop guide.
winship,
has given a perfect explination.
sk
michael lewis 03-27-2002 05:35 PM
Prop Question?
on props? is there a chart that tells thrust for props on size,pitch and rpm ?
winship 03-28-2002 02:36 AM
Prop Question?
Never heard of a chart concerning that.
Theoretically if the prop was 100% efficient didn't slip and was 10 pitch it would screw itself through the air 10 inches every revolution.
winship
hiroboz 03-28-2002 04:14 PM
chart
There is an excellent chart located at rcfaq.com Some very good info!
http://www.rcfaq.com/rpmstats/rpmindex.asp
Steve
CAPtain232 03-30-2002 01:46 AM
Prop Question?
Hi Steve,
The 18x6-10 prop can mean one of 2 things. Eithter way it is a variable pitch prop. It can be that at the root it has a 6 pitch and as the pitch travels down the blade it becomes a 10. It can also be the opposite of that.....10 at the root and 6 at the tip. The manufacturer determines this. Sometimes the manufacturers do this due to the inefficiency at the root.
Jeff
