multi- engine setup
I'm working on my first multi-engine model,(twin) and need advice on how to set up the throttle linkages
RE: multi- engine setup
Not sure how big your twin is, or which size/type engines you have, or how much room you have, .... but I am setting my twin up with 2 seperate servos. I am also going to use a Matchbox. With the Matchbox, you can use only a single channel on the radio, and fine adjustments (if needed) can be made individually to each servo.
Ensure that you use identical servos and try (if possible) to use identical size/type hardware. (PS: The MSA-10 is Futaba's version of the Matchbox). Bob |
The MSA-10 works great ,but if you have a radio with mixing you can just plug each servo into a seperate channel on your receiver and mix them from the radio. It will be cheaper and easier.
Austin |
oops, posted twice
| All times are GMT -8. The time now is 10:10 AM. |
