bill of materials
When building strictly from plans, how does one go about creating a bill of materials and selecting the correct type/size of wood for the various components? red 1 (aka Don Borton) AMA IMAA Waco Brotherhood #72 |
RE: bill of materials
you have to study the plans determine all the sizes and make a list. depending on the plans you are using its wood will have a certain look for the different types. some will just list as balsa unless otherwise noted.
Every time I get a set of plans to scratch build I unroll the plans and make a list of stock sizes and hardware needed. I then roll the plans up with the materials list inside and put them away until I am wanting to build it. When ordering balsa I usually order for 2 or 3 different plans at a time to save on shipping and if it is one I know I would want to build again if it is crashed, I order in enough to make an extra kit along with the build. Then I kit the plans and start building. The type of balsa is usually noted on the plan, but if it is not, you need to read up here on RCU for tips for what to use and where it is needed.
I learned a little from this book
http://www.amazon.com/Scratch-Buildi...2509312&sr=8-1 also there is a scratch building part of these forums that there are people willing to help you along. |
| All times are GMT -8. The time now is 06:37 PM. |
