RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Trying to find 48" Balsa wood (https://www.rcuniverse.com/forum/questions-answers-154/7912364-trying-find-48%22-balsa-wood.html)
cferrell2010 09-02-2008 02:23 PM
Hi, I have been trying to find a good place online to buy balsa sticks and sheeting 48" or longer I can only find 36" pieces.
BadSplice 09-02-2008 02:29 PM
RE: Trying to find 48" Balsa wood
These guys have some Balsa in 48" length.... http://www.nationalbalsa.com Ive never actually ordered from them, so cant say anything else one way or the other.
cferrell2010 09-02-2008 02:37 PM
Thanks for the link, I will give them a try.
Edwin 09-02-2008 02:54 PM
Balsa usa too. Bought some 48" stock last month. Just be patient with their user interface, its pretty slow.
http://www.balsausa.com/flash/index.html
Edwin
Gray Beard 09-02-2008 05:57 PM
Balsa USA.
CoosBayLumber 09-03-2008 08:35 AM
Depends upon your needs but I got a bunch at BALSADEPOT recently. The stuff from Mass. came in crunched and split up. Same as a few others have noted to me. Depends upon if you are a distant or local customer I think.
Wm.
Spitfire222 09-03-2008 01:17 PM
I saw an article in Model Airplane News a few years ago describing how to splice wood stock together to make longer pieces. I've used it a few times with success, you can give it a shot and save on ordering wood and just buy normal lengths from your LHS.
A few tips I remember from the article.
-Try to position the joint/splice where theres another structural assembly to support it (i.e. spar splice on a rib, longeron splice on a former)
-The total length of the splice should be approximately 8 times the width of the pieces you are splicing.
TedMo 09-03-2008 06:55 PM
Since the post was asking where he could get 48inch long sheets. what you stated has me flabbergasted. length of splice 8x the width. That would mean if I were spliceing a 3 inch wide sheet the splice would be 24 inches?
Edwin 09-03-2008 07:10 PM
Yeah! That really only works for sticks. (1/4w - 2" splice) Even then, if you can get 48" stock, why not. Everything I buy is 48".
Edwin
Spitfire222 09-03-2008 08:56 PM
Ted, the initial post also asked about sticks, and as Edwin stated, splicing works mainly for sticks. I should have been clearer.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
