Phaeton II CG ??
I have an old Phaeton II the 40 size, tha I'm trying to put back together. Could someone tell me where the CG is ?
thanks, paul |
RE: Phaeton II CG ??
Start with it near the leading edge of the lower wing then move it back as you check out the characteristics. Mine were best at about 1 inch back from leading edge of lower wing if I remember correctlybeen several years since mine expired.
Balsa USA calls for 6" back from the top leading edge on the center line.
This information is available on their website. Charles |
Thanx to all for your help
paul |
