Servo Speed
Can the normal sport flier tell the deference between a servo rated at .16 and say .20 @ 60 deg, does not seem like a big difference. Why I'm asking is for my GP 330L. Would like to use something like Hitec 645s. If I must go digital I will. Trying to save a little $. :confused:
Servo Speed
probably not, i have seen good pilots moan i've only got standard servos in my Cougar when the prophang it, but thats responce which i think this figure is, but 16 vs 20 is what, close to 25% which is quite a bit faster.
for joe average like us, you wont notice a thing |
Servo Speed
More than likely, you won't notice any difference. I personally like having a little more torque in lieu of more speed.
Servo Speed
and thats got more to do with where you put your links, not servo numbers
Servo Speed
Thanks for the info
Servo Speed
I would say that if you are flying a plane like a pylon racer or something similar, you should be able to see the difference.
| All times are GMT -8. The time now is 01:40 AM. |
