Does radio shack sell a varible load volt meter ?
Tower is out of thiers and Horizon wants twice as much. So, does R/S sell one ? I do have a VW on board but don't trust it. Thanks, Bob |
RE: Does radio shack sell a varible load volt meter ?
I dont think they do. that load meter is mainly an r/c product. it really cant be used for any other type of batterys. but I could be wrong
any voltmeter that applies a load the the circuit under test will do...some of you engineer gurus know what a good load should be?
RS sells some battery checkers, but I didn't see any suitable for our use. Any load from 0.25-1.0C I'd think would be fine. The idea is to draw enough current from the cells so they don't float. Ideally I suppose you'd want to measure with a load similar to what the battery will experience in use. A simple power resistor would suffice. Use V/I=R to find what size of resistor, and then P=vi to find the needed power rating. For a 4.8v 2000mah battery with a 0.25C load, that would be a 500ma load, so we need a resitor at 4.8/.5 = 9.6 ohms, call it 10 ohms. For power rating, that is 4.8*.5 = 2.5 watts. Double for safety margin, so load with a 10ohm 5 watt resistor in this case.
Thanks Guys, John, you way over my knowledge level. I thank you though. Bob |
It is very easy to make any voltmeter a loaded voltmeter. All you have to do is attach a resistor between the two probes, the size of the resistor determines the load. For a 4.8 to 6 volt (4 or 5 cell NiCad or NiMh) us a 10 ohm 5 to 10 watt resistor, for the 8 cell transmitter use a 22 ohm 5 watt. This will load them to about 500 milliamperes. Do be sure to use the higher wattage resistors, not the readily available 1/4 to 1/2 watt units. Make the load removable and you have a useful voltmeter for other uses. Even the very inexpensive ones will suffice for our use.
wow thats great info. I need a battery checker also. thats what Im gona do. thanks
Thanks Rodney, You wouldn't happen to know the nomenclature for the higher end resistors ? Bob |
One better, here is a resistor you could use. This is a 11ohm resistor rated for 5watts. It would work for testing 4.8v- 6v packs with an ~500ma load. RadioShack will probably have a similar resistor.
http://www.jameco.com/webapp/wcs/sto...ductId=660383& |
Thanks John, Bob |
