RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Covering Damage with Monokote (https://www.rcuniverse.com/forum/questions-answers-154/7964301-covering-damage-monokote.html)
ScienceisCool 09-17-2008 04:56 PM
Refer to this thread: http://www.rcuniverse.com/forum/m_7527666/tm.htm
I'm wondering how best to apply new monokote to the top and bottom of the elevator. One piece from top around to the bottom or two separate ones? Will it seal at the edges between old and new covering? This is my first go with a covering job.
Thanks!
DavidAgar 09-17-2008 10:04 PM
RE: Covering Damage with Monokote
You will want to remove the old covering as best as possible. For the best look in covering use 2 pieces and do the bottom first then the top. Good Luck, Dave
ScienceisCool 09-18-2008 11:24 AM
Thanks! I'll remove the covering from that side of the elevator and recover.
