how do I do a pull-pull rudder ?
I know a stupid question. I've been flying & kit building for almost 4 yrs. I've seen the pull-pull system but never really "seen it" if you know what I mean. Is there already a thread on this? If not, show me pics. Please. I'm finishing up a scratch built Midwest Super Hots (60 size) w/ a Super Tiger 75 & want to hook up a pull-pull. Thanks in advance
RE: how do I do a pull-pull rudder ?
buncha servo hookups.
http://www.angelfire.com/indie/aeros...rvoLayouts.htm |
Thanks, perreback & everybody else.. One thing I failed to ask. I'm useing a steerable tailwheel. Do I hook up the cables directly to the rudder & then use springs to the tailwheel? Or do Igo to the tlwhl first & use springs to the rudder? Thanks again guys
Alwasy hook cables directly to rudder. Use springs or other shock absorbing system between rudder and wheel.
1 Attachment(s)
Pull-pull tail wheel
1 Attachment(s)
This is A Mid West 60 size Hots I did A couple of years ago with A pull/pull. Because I'm running A YS 1.10 in it I also added two elevator servos and made up A hatch so I'm able to get to the rudder servo when needed. I was able to get almost all of my gear and battery behind the CG so I didn't have to add any lead to get correct CG. I also made up A much bigger rudder. This is my Get Real Stupid plane and it and my old Kaos get the most air time. This Hots gets with the program.
Thanks Tallpaul, APicture is worth a thousand words !!!
| All times are GMT -8. The time now is 12:46 PM. |
