charge switch question
Is this switch/charge jack any good? Any problems that you are aware of?
http://www3.towerhobbies.com/cgi-bin...?&I=LXPNU2&P=0 Thanks |
RE: charge switch question
I've used plenty of those switches and have had zero problems with them.
Ken |
I am replacing all of my switches with this unit. I have had 0 problems with this unit. You will still need to mount this in a dry area just as you would any switch to prevent any gas oil or moisture from entering.:D
I use the standard switches, but I mount them in one of these. Easy to install and they work great:
http://www3.towerhobbies.com/cgi-bin...&I=LXD665&P=SM |
Thanks guys. Just what I needed to know. I think I'll get both, the one I posted and the one Minnflyer posted. I am building a profile plane for my son, and it has a hatch to get to the battery. I wanted to be able to charge the battery from the outside of the plane.
Thanks again. |
Mesaflyer,
Those are good switches and a very good price. When I was using them they were around $16. I went to the standard switch with charge plug and replace the charge plug and use a 1/8" audio plug for charging. http://cgi.ebay.com/Hitec-Switch-Har...d=p3286.c0.m14 Much cheaper and round holes are easier to make. Good Luck, KW_Counter |
| All times are GMT -8. The time now is 05:43 AM. |
