RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   gas engine mess (https://www.rcuniverse.com/forum/questions-answers-154/854122-gas-engine-mess.html)
jemilheis 06-11-2003 05:18 PM
gas engine mess
I have a G-23 on a 1/4 scale Cub and am using Lawn-boy ashless oil. The oil makes a HUGE black mess on the underside of the plane. I have tried some cleaners and only smeared the oil. What cleaner will work on fabric covering and not take the color out? Thanks for your time and input. Jim
Flypaper 2 06-11-2003 05:44 PM
gas engine mess
Varsol or kerosene will cut it. Also sounds like your carb is set very rich. Should be coming out clear, unless you are running it rich for breakin.
bentgear 06-11-2003 05:53 PM
gas engine mess
Not sure what WD40 will do to that type covering, but just a mist of it on the spots and they wipe right off.
Ed M.
Divesplat 06-12-2003 03:17 AM
gas engine mess
I've used 409 on my cowls where the oil smoke trail builds over a # of flights. Am not sure about fabric though. Trya small area and see.
ed
jemilheis 06-12-2003 03:21 AM
gas engine mess
Thanks for the ideas. I am running the engine rich for break-in. The oil is being mixed at 32:1. I know it is a bit heavy, but I like to break-in engines slowly. They seem to last longer.
visioneer_one 06-12-2003 03:50 PM
gas engine mess
Get some high-temp silicone tubing from Aerotrend of the appropriate diameter and use it to extend the length of your exhaust stack(s). This won't eliminate the oil mess but will at least move it a little further away from your airframe.
Stick Jammer 06-12-2003 04:52 PM
gas engine mess
That LawnBoy ashless oil could be contributing to your problem with excessive carbon build up. You might try switching to a high grade/high performance oil more suited to the task.
jemilheis 06-13-2003 02:52 AM
gas engine mess
Thanks guys. I thought about switching oils. Even with my BME I have the same oil mess. Any suggestions on oils? Thanks Jim
Stick Jammer 06-13-2003 11:08 AM
gas engine mess
Synthetics: Amsoil, Klotz, Honda HP2
Petroleum based for break-in:
Penzoil for air cooled engines
Castrol 2-cycle
Kraut 06-13-2003 11:48 AM
gas engine mess
I recommend you try a product called "Opti-2". It is a 2 cycle engine lubricant that produces no smoke from the exhaust, and it can be used in any 2 stroke engine (that requires oil mixed in with the gas) - regardless of the mix ratio. From what I understand - it has teflon in it - and it treats the metal to reduce the friction, unlike oil - which just relies on a thin film barrier to reduce friction. I have been using it in my gas 2 strokers - and it is amazing! No smoke, fires right up, and runs like a champ. You can use it in your chainsaw, your weedeater, and your big R/C gasser - regardless of the mix ratio. I got mine from our local Ace Hardware store - and the fellow that owns the store said that if he had his way - Opti-2 would be the only 2 stroke additive he would stock - it's that good! It comes in a small plastic tube in either 1 or 2 gallon sizes. Our CE (Civil Engineering) unit on base has been using it for years on all their 2 strokers - and they "swear" by it!
jemilheis 06-13-2003 06:39 PM
gas engine mess
Kraut, thaks for the info. Thanks again to all. Jim M
rfw1953 06-14-2003 03:59 AM
gas engine mess
I had the same problem. I had a guy on RCU recommend Sthil 2 cycle oil and to use the engine recommended oil to gas ratio. I did and was really amazed at how much cleaner it ran. I use fantastic to clean up after wards and it works well. I also heard from several posters that synthetic oil should not be used for engine run-in. Apparently it can cause the rings to not seat properly. After break in it's ok to use. Just what I have read on the subject. Sure there are different opinions. Thought I would pass along.
I am a first time gas engine user so not an expert and learning.
SST 06-14-2003 01:00 PM
gas engine mess
When all else fails, go to the marine dealer and get some OMC or Mercury outboard oil...SUPERIOR STUFF!! Mix at recommended ratios.
Stick Jammer 06-15-2003 02:46 PM
gas engine mess
Actually, outboard oil is not designed for air-cooled high performance engines as they get much hotter than a water cooled outboard.
bob_nj 06-15-2003 05:41 PM
gas engine mess
To answer your question, try a couple of spray bottle products called, "Goof Off", and "Goo Gone." ;)
big max 1935 06-16-2003 12:11 AM
gas engine mess
Mix 2 & 1/2 OZ bottle Stihl oil with 2 gallons gas . Dealer says thats about 40 to one . Really works great & very little to clean up . Readily available at about a $1.50. Used it for years .MAX H.
jemilheis 06-17-2003 09:27 AM
gas engine mess
Thanks for all the help. Jim M
jemilheis 06-17-2003 07:26 PM
gas engine mess
I just tried a product called "GOO GONE" recommended by bob-nj. What some great stuff. I just sprayed it on and the oil literally melted and ran off my airplane. It also left it smelling rather fruity. $4.50 at my local Wal-Mart. Thanks to all who replied. It is nice to see people lending a helping hand when needed. Thanks again Jim M
fishgod 06-17-2003 08:21 PM
gas engine mess
Actually you need 3.2 oz of oil to 1 gallon of gas for 40 to 1 and 2.56 oz of oil for 50:1.
Stick Jammer 06-17-2003 09:16 PM
gas engine mess
jemilheis,
Keep in mind that if you are getting that much black residue that something isn't quite right to begin with. Your engine is getting too much carbon build up. As mentioned before, try a better 2-cycle oil and see if the mess goes away. That is one of the best things about switching from glow to gas, very little or no mess to clean up.
big max 1935 06-19-2003 03:16 AM
gas engine mess
fishgod: Guess I was in another bottle when I said the large bottle of Stihl oil was 2.5 oz , it is 6.4 oz . That makes like you said 40 to 1 mix. MAX H.
Blackie 06-19-2003 04:15 PM
gas engine mess
I'm not a gasser as of yet but as far as cleaning up the mess Go-Jo hand cleaner will cut that oil film.
Blackie
mikenlapaz 06-21-2003 10:04 PM
gas engine mess
Goop Hand Cleaner 14 oz tub from local $ store for about a buck.
The ultimate stain lifter.
jemilheis 06-22-2003 08:59 PM
gas engine mess
Thanks for all the good advice. I did switch oils. Now if I could only get the darn thing to run right. Thanks again.. Jim M
