RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   manually control speed (https://www.rcuniverse.com/forum/questions-answers-154/9072313-manually-control-speed.html)
billcat 09-05-2009 06:09 PM
is there a product available or DIY schematic for a simple knob or slide switch that you can control a speed controller with to use for testing the controller without using the normal radio control setup? I want to be able to bench test different setups without using a radio. thanks
The Ghost 09-05-2009 09:26 PM
RE: manually control speed
1 Attachment(s)
You need to get your self a watt meter or simmilar. I use a meter from Turnigy and it measures Amp draw, Voltage, Mah used as well as live time watts, so you can see straight away if the changes are better.
Or for a couple of dollars you can buy just a servo driver.
Cheers
billcat 09-06-2009 11:38 AM
thanks Ghost, the pictures show exactly the thing I am looking for.  I didnt know what to ask for. Greatly appreciated!
