RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Balsa USA Enforcer (https://www.rcuniverse.com/forum/questions-answers-154/92486-balsa-usa-enforcer.html)
crash86 04-01-2002 12:42 AM
Balsa USA Enforcer
I have just completed an Enforcer. I have not flown it yet and would appreciate hearing from anyone who has built one and flown it. I would hate to crash it on it's maiden flight because it has some quirks I am not familar with.
Thanks, Crash86
DF_Flyer 04-02-2002 10:44 PM
Enforcer
I built the Enforcer's little brother, the Force One, a few years ago, and the one thing that I clearly remember is that its roll rate at the manufacturer's recommended aileron throws was way too much. This could have been because I used gapless hinges, but it was really touchy until I reduced the aileron throws. You might want to consider using your lower rate for the takeoff until you get some altitude built up. Hope this helps.
crash86 04-02-2002 10:56 PM
Balsa USA Enforcer
To DF_Flyer:
I really do appreciate your answer. One more question, did your plans indicate to put about three degrees up elevator and ailerons as normal settings?
Crash86
Dave Barrow-RCU 04-02-2002 11:20 PM
Balsa USA Enforcer
I had an Enforcer about ten years ago, it was a very good flying plane. I don't remember the aile-elev settings I had, but they were less than the instructions said. The three degrees of up elev-aile, is for slow flying stability. The only bad habit it will have, as a delta wing, is it will lose airspeed quickly in turns. Keep some power on through the turns and you won't have any problems. I am building another Enforcer now, but it will be Byron ducted fan powered.
LDaba 04-03-2002 02:39 AM
Balsa USA Enforcer
Crash: I posted in another forum on the flying characteristics of the Enforcer and heard about the speed bleed off in turns and a nose high attitude on final. Also the up elevator,or reflex, is necessary because of the delta wing configuration.
I have an Enforcer in the "to be built" pile.
I plan to do it as a SAAB lookin fighter, complete with Sweedish insignia, NATO camouflage and minigun/missle armament. It will also have retracts. I plan to use a Super Tigre .75 for power.
Good luck with yours.
Happy landings Tony ;)
crash86 04-03-2002 06:23 PM
Balsa USA Enforcer
I want to thank everone for the good information about the Enforcer. I plan to use a GMS .60. I have never flown a pusher but I assume it will fly about like the tractors. Some of the projects you guys are trying sound very interesting. Keep us informed.
Crash86
DF_Flyer 04-04-2002 02:55 AM
Balsa USA Enforcer
Crash 86 - (Sorry for the late reply) I did put some up in the elevator and ailerons on my Force One. 3 degrees sounds about right.
BTW, one of my favorite things to do with the plane is to bring it in for really nose-high landing and control the sink rate with the throttle. If you use a little imagination it looks like the space shuttle coming in. After a little practice practice you will even be able to hold the nose off the ground for a few seconds after touching down. Please let us know how yours flies.
crash86 04-04-2002 11:36 PM
Balsa USA Enforcer
Well, I thought I had it ready to fly but, I felt I had too much slop in the controls so I'm going to mount the servos in the wing for all controls. That means tearing the covering off the bottom of the wing. Soooo! It will be a while before I get to fly it. Thanks again for all the answers. Keep e'm flying!!
Crash86
Ed_Moorman 04-05-2002 02:16 PM
Enforcer
I test flew and trimmed one for a buddy and it flew fine, not sensitive at all. You do need reflex in any tailless design. His was even tail heavy. I had to use down elevator to get it to descend on final approach and even then, it wasn't overly sensitive.
miken96-RCU 07-29-2002 01:30 PM
More questions
I am preparing to build one for the purpose of a Cross Country Event. I am planning on a .91 or 1.20 4 stroke with a 50oz fuel tank. I need the fuel load because one of the legs is over 58 miles. I am figuring that with the economy of a 4 stroke over a 2 stroke I SHOULD be able to make it. A friend of mine has one with a 2 stroke .61 engine and a 28oz fuel tank. We could get about 25 miles to a tankfull at 45MPH. Am I off base here or will I need something different.??
TIA
crash86 07-29-2002 04:17 PM
Balsa USA Enforcer
Thanks everyone for the good information. I have the bird finished but I haven't flown it yet. Going to have a test pilot fly it first as I am 79 yrs old and my reflexes are a little slow. I'll let you know. Those great big fuel tanks sound awsome!! That sounds like a fun cross country though. Wish I could see the jet fly. The reason I call myself Crash 86 is: I crashed one on landing in Korea. A Mig 15 got me.
CLBetten 07-31-2002 04:26 AM
Enforcer
I have eight planes flyable at the moment and the Enforcer is my newest. I am using an OS91 four stroke with a 14x6 and 14x8 prop. If I were going to point out "quirks" about the flight characteristics I would warn you to be prepared for difficulty of orientation "a delta norm". With no rudder control take offs and landings in cross-winds can be tricky and require a fairly careful coordination of down elevator to keep enough weight on the nose gear so the plane doesn't take off prematurely and weather-vane directly into the crosswind. When you throttle back quickly it will also balloon a bit. With mine at full speed if I move quickly to idle it will balloon about 12 feet with no control input. Landing approaches require pushing the plane down a little and a little power to keep from stalling. Once I have gotten past the surprise of discovering these "and please note that I can make no claim to fame as an RC pilot" I have had a blast with my Enforcer. Once up to speed it flys quite level. The sound of the prop. swinging through the slot in the wing is a real attention draw. I love to get it in spinning fast just to see how easily it recovers. I am sure it will never win an I.M.A.C. contest but of all the "unique" looking planes I have flown it is surely my favorite. I can't wait to try it on skis! Enjoy flying, Cliff
eugene 07-31-2002 12:24 PM
Balsa USA Enforcer
two things I would recommend,,ditch the long aileron pushrods and add servos in the wings, also check the CG very carefully..like most delta wings they take sone adjusting to their quirks, but it is a fun airplane...
ADSPATTERN 08-31-2002 02:40 PM
Balsa USA Enforcer
I am thinking of buiding the enforcer. I like what I'm hearing about the flights. But, what about the building? How easy does it go together? I've never put anything like this together before (delta wing).
crash86 08-31-2002 03:31 PM
Balsa USA Enforcer
ADSpattern
I was a novice at building the Enforcer. I made a big mistake on the leading edge. The plans say to curve the leading edge skin over to the leading edge strip. Leave 3/32" above and below the rib when you glue the leading edge strip on. Run the balsa covering up to the 3/32" you left. Then shape the leading edge to the airfoil. I (stupidly) tried to curve the balsa over the leading edge. I knew better but did as the plans showed. As a result, I sanded the balsa so thin trying to shape it, I had to glass the wing back to where the covering began. Lot of work for nothing!
Also I agree with the comments above, place the aileron and elevator servos in the wing. You get nothing but slop doing as the plan shows.
Crash86
ADSPATTERN 09-02-2002 01:19 PM
Balsa USA Enforcer
Thanks, Crash86 sounds like it's not going to be that bad of a kit.
Frazzy 09-04-2002 02:29 PM
Balsa USA Enforcer
Hey crash86, you are building the right plane. I just built one this last winter and finally finished it up a couple weeks ago and flew it. I posted a small review at this link
http://www.flightlines.com/forum/For...ML/000139.html
I also have a few pictures in another forum there....http://www.flightlines.com/forum/For...ML/000189.html
Just make sure you cover the thing in bright colors and also contrasting colors on the top and bottom as it is real easy to be disoriented. Mine flew almost perfectly on its maiden flight. And it is the coolest plane I have ever landed. A real blast.
miken96-RCU 09-04-2002 10:09 PM
RE: Frazzy
What size Engine/Prop are you using, and what is the listed ground clearence from the engine to the ground??? Just trying to figure out my prop delimea...
Frazzy 09-04-2002 10:45 PM
Balsa USA Enforcer
Miken, I just went and measured. I am using an OS 91 Surpass with a 14x8 zinger pusher prop. I measured 2 1/2" ground clearance.
miken96-RCU 09-04-2002 10:50 PM
RE:
Frazzy,
I have a Saito 120S 4 Stroke I want to install and I am worried about ground clearence if I use a 15X8 Prop??? In your Humble opinion? Am I gonna be safe??????
miken96-RCU 09-04-2002 11:02 PM
Balsa USA Enforcer
Hey,
How TALL is the landing Gear???? I have a Fults Nose Landing gear and I plan on a Filts Main gear. If I was to lengthen the gear by 1", then my 1" larger prop wouldn't have any problems??? Just figured I would ask the question!!!
Thanks for all the replys!!!
Frazzy 09-04-2002 11:04 PM
Balsa USA Enforcer
Well, I would think so. Balsa USA's site now lists powerplants up to 120 four stroke. Besides, a 15" prop is only 1/2" longer on the ground side anyway, giving you 2" clearance, at least on my plane.
miken96-RCU 09-04-2002 11:06 PM
Balsa USA Enforcer
Thanks for all the reply's....... I expect my kit to arrive tomorrow, and I plan on finishing it to include a maiden flight on the 21st or 22nd.... If you have read earlier, I am going to put a 50oz fuel tank in it and fly it in a cross country event. The longest stage is about 70+ miles, so you can understand the need for a LARGE fuel tank and HUGE motor!??
Frazzy 09-04-2002 11:13 PM
Balsa USA Enforcer
Sounds like quite a project you have going. I didn't measure the landing gear length. I used the stock gear. you could even use larger diameter wheels if ground clearance is a problem. But I don't think you are going to have much trouble with a 15" prop and stock gear. I fly off of buffalo grass. Admittedly it is cut short.
Well, anyway good luck in your adventures and I will help if I can.
miken96-RCU 09-04-2002 11:16 PM
Balsa USA Enforcer
I fly off Pavement as a rule.. New mexico does not have that much grass or that many grass fields....
You have been a tremendous help!!!!
