Servo tray material ?
Where can I find that carbon fibre/bakelite looking material that is used to make servo trays ?
thanks, paul |
RE: Servo tray material ?
What about electrical Breadboard/Circuit board material from radio Shack?
Just a thought.:D |
I have used 1/8" lite -ply w/1/4" spruce glued to the bottom at each end of the servo holes for the screws to bite into. Used it on 1/4 scale on down with no trouble . Cheap ! Max H. :)
Dreamworks sells a simulated carbon sheet made of ABS plastic.
http://dreamworksrc.com/catalog/prod...roducts_id=172 |
ORIGINAL: big max 1935 I have used 1/8'' lite -ply w/1/4'' spruce glued to the bottom at each end of the servo holes for the screws to bite into. Used it on 1/4 scale on down with no trouble . Cheap ! Max H. :) |
I've used high quality fiberglass PC board material before and it works fantastic. The copper clad can be removed fairly easily with a propane torch if you don't want the copper on it. Easy to work with and very rugged.
| All times are GMT -8. The time now is 06:00 PM. |
