RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Kevlar for pull pull. (https://www.rcuniverse.com/forum/questions-answers-154/945737-kevlar-pull-pull.html)
Handyandy2 07-10-2003 10:47 PM
Hi
I read that quite a few fliers are useing Kevlar for pull pull systems. Where can I purchase some.
thanks
Handyandy
TomCrump 07-11-2003 12:12 AM
pull pull
Tower carries the Sullivan system.
MHawker 07-11-2003 12:20 AM
I got mine from my local hobby shop. Just one word of caution with kevlar. Make sure it does not rub anywhere. It will fray and break. I could have lost a 25% Extra due to this. Luckily, I had a reason to pull off the covering and saw it was already fraying.
I'd suggest getting the steel cable set up. It's just as easy to install and safer IMO.
CrashMeister 07-11-2003 02:22 AM
Get Kev-Cord from ACP composites. It has a vinyl coating to protect it from fraying. Also get their 4-40 bolts with the hole through the middle, very easy setup.
See http://www.acp-composites.com/acp-cord.htm
Craig.
ml3456 07-11-2003 12:25 PM
Don's Hobbies also sells a coated Kevlar kit
ML
Spaceclam 07-15-2003 04:59 PM
i agree, kevlar frays, i used to have to replace it every month on my nosewheel brake. guitar strings work well.
CurtD 07-16-2003 01:31 AM
The Sullivan Kevlar pull-pull kit uses coated kevlar but you should still be careful to not let it rub anywhere.
