RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   building help (to sheet or not to sheet) (https://www.rcuniverse.com/forum/questions-answers-154/9496852-building-help-sheet-not-sheet.html)
jimmyjames213 02-11-2010 08:31 PM
1 Attachment(s)
im building a profile (scratchbuilt) that is very similer to the tower fun-51. it has about the same airfoil only the wing has been extended 2 bays making it about 52 inches. (compared to 44)
the fuse has been extended about 4 inches and the rudder/elevator servos will now be in the tail. (its about 3 feet 3 inches)
heres a pic of the fuse.....
do you think i should sheet it? im thinking of throwing a magnum 46 or 52 for the engine. the plane will be for 3d (if it even flies). the fuse is made out of 3/8in balsa while the origional th fun 51 used 1/4 balsa for the fuse and it was sheeted
also should i fiberglass the center section of the wing since its much bigger?
Lnewqban 02-11-2010 10:21 PM
RE: building help (to sheet or not to sheet)
I vote for sheet.
Even very thing balsa skin will add a lot of strenght and rigidity.
Recently, Bob Hunt wrote several articles in AMA magazine about this in the CL section.
He recommends lite-fiberglassing over the skin, as well as the center of the wing.
huck1199 02-11-2010 10:30 PM
If you can keep your wing loading about the same use sheeting.  Weigh some pieces of sheeting and see what you get. You have expanded the model about 30% but wieght might not increase proportionately but one of the critical parameters for 3D is wing loading.
