Does the DLE 55 have more power than a zenoah g62?
I keep hearing the DLE 55 have more power then the zenoah g62. Is this true??
RE: Does the DLE 55 have more power than a zenoah g62?
I guess it depends how you measure power. I replaced a G62 with a DLE55 on a GP Ultimate. The G62 had already been lightened by converting to electronic ignition and use of a Bennet muffler. The same prop, Bambula 23x10, is used on both. The DLE pulls the plane with much more authority, but then again there is a 2.2lb weight difference.
I like the Zenoah's and do believe that for longevity nothing compares. The weight and cost is a problem though. To outfit a G62 with electronic ignition and a lighter muffler makes it much more expensive than the DLE. Bliksem |
Hi!
How does this compare with a MVVS 45cc ...turns a 24x8 "Mentz" at 6600 rpm. |
ORIGINAL: jaka Hi! How does this compare with a MVVS 45cc ...turns a 24x8 ''Mentz'' at 6600 rpm. Large, why don't you go into the gas engine forum and start reading about what others have to say about the different gassers you are looking at. I was also a big fan of Brison and love the 2.4 I have, people compare it with the DA 50. As sweet as it is I just don't know if I could compare the two?? Comparing anything is way too hard and you can't go by the factory specs very much either, the HP rating is about useless. |
I have both....and I have spun the same prop on both. The G-62 is smoother all around and wins hands down every time!!! ;) The DL is lighter and can be used on a larger variety of airframes. The G-62 will be around for years and years after the DL has turned to dust. They are two different engines that are indeed very different from each other.....so much so that it is not fair to compare them IMHO.
Would the zenoah g62 be good for my p-51 at 26 pounds with NOengine yet? Its 26 pounds, retracts, and sheeted, fiberglassed fuse and wing, no engine yet. Engine is about 5 pounds or so about 30 31 pounds. Will this work good?
ORIGINAL: LargeScale88 Would the zenoah g62 be good for my p-51 at 26 pounds with NO engine yet? Its 26 pounds, retracts, and sheeted, fiberglassed fuse and wing, no engine yet. Engine is about 5 pounds or so about 30 31 pounds. Will this work good? |
ORIGINAL: Gray Beard ORIGINAL: LargeScale88 Would the zenoah g62 be good for my p-51 at 26 pounds with NO engine yet? Its 26 pounds, retracts, and sheeted, fiberglassed fuse and wing, no engine yet. Engine is about 5 pounds or so about 30 31 pounds. Will this work good? All kidding aside, if he is going to put over 5 lbs. of G-62 up front, then why not put the DA 85 up front, it would be very close to the same weight said and done. He stated that he wanted to go really fast with this airplane, well with 8.5 HP up front and the right prop, he would be at the top of his game. We are getting radar speeds of 123 MPH, flat and leval, and on calm days on our aerobatic 1/3 scale airplanes using 3D props and stock exhaust on the DA 85s, so with a clean airplane, and speed prop, look out...:) Bob |
I've read lots of people who have p-51s that are like 35 to 40 pounds with a zenoah g62. I think it will get off the ground, may not be fast. It will prolly fly ok though.?
ORIGINAL: LargeScale88 I've read lots of people who have p-51s that are like 35 to 40 pounds with a zenoah g62. I think it will get off the ground, may not be fast. It will prolly fly ok though.? |
Well, from what you told me, I need to choose a bigger engine. 3w75 would be a good choice??
My DLE55 is on a plane thats under 16 lbs :D
Gray Beard is correct. A G-62 will fly a 31 lb P-51 just fine. Just don't expect to be performing IMAC routines with it. I've seen more that one Byron P-51 @ ~30 lbs fly on a G-62 and a Byron Hellcat as well. I've flew the Byron Hellcat at 31 lbs. It was reasonably fast and although it would not do a very big loop, small loops were ok, and it would do most acrobatics maneuvers you would expect to see from a warbird. Another point of reference is I had an Ohio Extra 300 @ 24lbs powered with a G-62/Mejzlik 22x10 clocked at 117 mph straight and level.
