Help!!!!! please
Can anyone please tell me if I can use the DX7 radio and a AR6200 reciver and I want to hook up my rear stab servos on two channels. I have done it with a AR7000 no problem but when I try it with the 6200 and I get to the part on the radio where itsay aux2 the 6200 has only a aux1 and I can't get it to work. I have it working on my jet but that has the 7000 in it does this make a diffence?? Is there a way to change the aux2 to aux 1? When I try the arrow just skips right over it. 1.) Access the System Mode
a. Scroll to the Input Select screen and change AUX 2 to INH. b. Change FLAP to SYS 2.) Press Access (Down & Select) once to return to the main screen 3.) Press Access a second time to access the Function Mode a. Scroll to Program Mix 5 or 6. b. Press Increase to activate the mix. c. Set the mix as FLAPĂ* AUX 2 d. Set the rates as 100% for both up and down (move flap switch to move small arrow next to rates) e. Set SW: ON. 4.) Press Scroll to Flap System screen and set flap values for neutral, mid and land. Can you do this for the rear stabs on a AR6200?????????????????? |
RE: Help!!!!! please
It can be done. I have done it. I haven't owned my Spektrum in a while though so I forget exactly how I did it. I'm almost embarrassed to say that since I normally tend to remember stuff.
I think though that I used mix #5 or #6 to slave flaps 100% to elevator (Or aileron, rudder, whatever you want as the master). I then went in through one of the menus and disabled the flap switch. It was something like that anyhow and it worked well. |
They say the mind is the first thing to go. I can second that!! I will try what you are saying about the flap part and see what happens. Thanks
| All times are GMT -8. The time now is 02:35 AM. |
