Hobby Zone Super Cub
I have the Hobby zone super cub and now i when I fly it i can throttle it up to about 75% and then the engine quits. I have changed the battery on it and on the transmitter and it still does weird stuff. Got any suggestions?
RE: Hobby Zone Super Cub
Possibly the esc is cutting out at that amp level.
I second that motion. I had a brushless setup one time, and changed prop pich, diameter. Every time I would throttle past 60% the esc would overheat and cut out. Did you chang anything on it, and did it do this from the start?
| All times are GMT -8. The time now is 03:31 PM. |
