Plane Plans
Hello
Is there any place in Australia that sells Warbird plane plans, am looking at building a P51 with retracts and needs to as large as 1.2 metres in wing size or above. Thanks dutchy50 |
RE: Plane Plans
Can't help you for OZ plans but Model Airplane News has plans for a 101 inch P-51 designed by Dan Santich that is really a nice plane. Plans number FSP04961. ;) Just an FYI
RE: Plane Plans
You could order the Airbourne Plan (Page 13)and enlarge it a bit.
http://www.airbornemagazine.com.au/planHome.htm I would order the MAN plan, I will see if I have a copy of the Mag it was in. Johnkpap |
RE: Plane Plans
I don't have the Mag for the giant P51
The MAN mag you want is:- Giant P-51 Mustang FSP04961 April 1996 Johnkpap |
RE: Plane Plans
ORIGINAL: Gray Beard Can't help you for OZ plans but Model Airplane News has plans for a 101 inch P-51 designed by Dan Santich that is really a nice plane. Plans number FSP04961. ;) Just an FYI |
RE: Plane Plans
I read this as a request for a relatively small model, not for a 100 inch giant.
A wing span of 1.2 meters is approximately 47 inches. If you're willing to go with a kit versus building from plans, the Great Planes 40 size P-51 is designed to be able to use retracts. It has a 57 inch (1.4 meters) wing span. |
| All times are GMT -8. The time now is 12:09 AM. |
