RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Transfer tape for installing decals (https://www.rcuniverse.com/forum/questions-answers-154/9726327-transfer-tape-installing-decals.html)
shaggy48 05-11-2010 12:54 PM
The instructions for installing decals on my plane calls for using transfer tape. What is "transfer tape". Is this something specifically made for this purpose or can any clear household tape be used?
Shaggy
BarracudaHockey 05-11-2010 04:03 PM
RE: Transfer tape for installing decals
Its a very low tack tape thats usually used for applying vinyl lettering. You can use masking tape.
shaggy48 05-11-2010 06:15 PM
Glad I asked before using anything
Thanks!
tailskid 05-11-2010 09:59 PM
You can also try that sticky stuff your better half has in the kitchen - "Cling" or something like that - looks like waxed paper but has a sticky side to it.
Dsegal 05-12-2010 08:08 AM
What exactly are you trying to do? If you are installing sticky-backed decals, such as a large, single item like a national insignia forget the tape. Use a soap solution on the plane, slide the decal into position and then squeegee out the liquid, blot and allow to dry. But if you have a string of lettering which must be lifted, as a unit, from the vinyl sheet then you need a strip of tape to "transfer" the lettering. Transfer is a function here, not a type of material. You can use a low tack tape such as blue painter's tape.
