RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Finish (https://www.rcuniverse.com/forum/questions-answers-154/975666-finish.html)
jacs 07-20-2003 08:02 PM
Finish
Hi
One quick question about finish. A paint shop said that I should use Standox Easy (a 2 component finish). I have applied it and after 24 hours dry it is hard and god. One flight later after removing oil and others the surface is sticky in that area that hade the spray from the engine. Have anybody some ideas?
Regards
Jacs
DBCherry 07-20-2003 10:50 PM
Finish
It means that your finish is not fuel proof.
You'll need to find a compatible clear coat that IS fuel proof and cover it with that.
Dennis-
jacs 07-21-2003 06:45 AM
Finish
Had the same problem with the old celolusa clear coat that span silccover. It's fuel proof if I don't use nitrometane. I need to know what you guys are using.
jacs 07-21-2003 10:44 AM
Finish
Found the problem a friend told me to get in touch with a guy that fly airplanes and has a paint shop and he told me that the clear coat has to harden for a week before you fly.
