Elevator mixing
I want set both Elevators adjustment on the tirm tab on the radio? Currently I fly with DX7 and have the left elevator on ELEV channel and the right elevator on AUX2 on the receiver.
They are mixed on number 1 mixing Elev - Aux2 ON Rate +100% + 100% SW : ON Offset : +1 When I am in flight if I adjust trim then only the left elevator moves, is there a way to have both moving on the trim tab so you can adjust equal amount in flight ? I don't like using the Y leads with the reverse set up as I have seen them go out of adjustment due to heat on a sunny day. Brian |
RE: Elevator mixing
Age old problem with most transmitters that the trim does not follow on the slave channel
RE: Elevator mixing
Basman
Elevator and AUX 2 are OK but you need to use either mix 5 or 6 on the DX7. This will do what you want, ie the trim will move both elevator halves. It's mentioned somewhere in the instructions, I have it working on a couple of models with dual elevator servos. Terry |
RE: Elevator mixing
Sweet Terry..................thanks for that, just goes to show when all else fails read the instructions ....Brian
| All times are GMT -8. The time now is 06:06 AM. |
