RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Dual Elevator Servos programming and DX6i (https://www.rcuniverse.com/forum/questions-answers-154/9888446-dual-elevator-servos-programming-dx6i.html)
timcat26 07-26-2010 12:03 AM
Morning all,
I'm trying to work through the DX6i manual to get to the proper programming to use dual Elevator servos with a DX6i, and not having a whole lot of luck. Can any of the experienced with this radio lay out what I need to do to use this feature with this radio? I'm looking for which Rx port to use with which side of the elevator and which one to assign to Aux 1, along with the programming to get them working and reacting to changes in things like trim adjustments simualtaneously.
If it matters, this is for a .60 U Can Do with an AR6200 Rx and Spektrum DS821 Servos.
I watched one of our members put in a 30% Extra on a Maiden due to programming errors on this function, so I'm a little concerned, to say the least, about getting this right. Thanks in advance for any input.
timcat26 07-28-2010 12:21 AM
RE: Dual Elevator Servos programming and DX6i
39 views and nothing? Really?
OK, I got in touch with Spektrum and they suggested using Mix 1 and programming in Elevator=Gear, 100%-100%, and enabling Trim. I've done this programming and will try it in the morning. Anyone know what "Setting D" means, the default for the radio?
