A Flying Four Stroke in Winter
What's a dependable procedure to get a four stroke running in the dead of winter? Seems my Saito's have always been "riga-mortise" stiff while the two-stroke fire without hesitation? Appreciate your help.</p> |
RE: A Flying Four Stroke in Winter
Try a few drops of Ronsonal lighter fluid to get em started .
The lighter fluid works if you can get to the carb. Our winters only get down into the 20s and most the time it's in the 30s. Mine still don't like to fire up. I use my power panel and let the plug warm up a little before I roll them over. I have seen some guys stick there engines just under there cars exhaust pipe to warm them up before starting. It's a pain but it seems to work.
Run it slightly richer than you had been in the summer. The cool air is denser
Most of us pull the fuel line off the carb or remote needle assemble to refuel the plane. On my 2 strokes, I just shoot alittle bit of lighter fluid into the carb, & off she goes. On my 4 strokes, I fuel as always, but before I hook up the fuel line , I shoot a little bit of lighter fluid into the fuel line & then rehook. Priming brings the lighter fluid to the engine & it starts first time. On my cowled engines were I fuel through a third line or a fuel dot, I shoot it into the exh & hand rotate the engine backwards to get the fluid into the cyl, then hit it & again, always fires up. Bill
What the others have said. Just a few drops of lighter fluid either directly into the carb or in the fuel line and she'll fire right up.
This could also work, http://www.featurepics.com/online/Ca...ure293337.aspx :D:D
I like that the best of all
ORIGINAL: Charlie P. Run it slightly richer than you had been in the summer. The cool air is denser Stay warm!!!! |
ORIGINAL: Augie11 ORIGINAL: Charlie P. Run it slightly richer than you had been in the summer. The cool air is denser Not entirely sure why this works but it just does. Stay warm!!!! |
ORIGINAL: da Rock ORIGINAL: Augie11 ORIGINAL: Charlie P. Run it slightly richer than you had been in the summer. The cool air is denser Not entirely sure why this works but it just does. Stay warm!!!! |
Hey Graybeard it was 39 here this morning! I don't know how you AZ guys fly @ 100+degrees. When it gets that hot I declare it 'building season'.
Vegas and it's cooler here then AZ. When it's hot here you have to remember the humidity factor, there isn't much here, it's more like fire, very dry so when it's 85 it's really nice, 100 isn't bad, 110 to 115 sucks!!!! During the summer we fly from sun rise to about 9:30 or 10:00 then get the hell into our air conditioned vans and head home. Winter it is in the 30s and 40s and you can't feel your finger tips, spring, summer and fall are great, I didn't move here for the cold.;) I thought I left the snow behind me too but I was wrong again. Last year was wet for us and the dry lake bed didn't stay so dry. I really did give floats a thought and may build a small float plane just for those special times, 7 sq. miles of shallow water, sounds good to me.:D
Sorry Graybeard.......I read NV and thought AZ. Next my inside loops will become outside. Yes, AZ is hot. I helped a buddy out at the Scale Masters in Mesa a few years back. Great club hosting a great event but I was dying from heatstroke and it was October. But don't give me the dry heat routine we use that out here in CO as well! Our winters are cold /snowy but nothing like back East. It's a 'dry' cold :).
ORIGINAL: Augie11 Sorry Graybeard.......I read NV and thought AZ. Next my inside loops will become outside. Yes, AZ is hot. I helped a buddy out at the Scale Masters in Mesa a few years back. Great club hosting a great event but I was dying from heatstroke and it was October. But don't give me the dry heat routine we use that out here in CO as well! Our winters are cold /snowy but nothing like back East. It's a 'dry' cold :). |
ORIGINAL: Gray Beard ORIGINAL: Augie11 Sorry Graybeard.......I read NV and thought AZ. Next my inside loops will become outside. Yes, AZ is hot. I helped a buddy out at the Scale Masters in Mesa a few years back. Great club hosting a great event but I was dying from heatstroke and it was October. But don't give me the dry heat routine we use that out here in CO as well! Our winters are cold /snowy but nothing like back East. It's a 'dry' cold :). |
