New manual for 85"
Old 03-27-2006, 08:20 AM
FredRasener
Default New manual for 85"
Hello everyone, I too have a brand new 85" Yak and a new DA50 for power. This promises to be an awesome aircraft.
Since I have yet to start construction I would like to know when the new manuals are expected to be done.
Right now I am working out a trim scheme as my Yak is the all white version.
THANKS
Fred Rasener
FredRasener is offline
Old 03-27-2006, 09:51 AM
Rezagh
My Feedback: (73)
Default RE: New manual for 85"
Hello Fred,
New manual will be released in a week or so from today. Meanwhile if there is anything vague, let me know and I'll help you.
Thank you,
Reza
Quique's Aircraft Support
Rezagh is offline
Old 04-03-2006, 02:45 PM
JustABigKid
How's the updated 85" manual coming? Any news?
JustABigKid is offline
Old 04-03-2006, 03:22 PM
Rezagh
My Feedback: (73)
Great News! I'm done with the manual. You are probably the first to have it. Please let me know what you think.
Soon it will be available on the website and we will have copies at Toledo show also.
Thank you for waiting,
Reza
P.S I can't upload it here as it doesn't accept .pdf format. You would have to send me emails asking for one
Rezagh is offline
Old 04-03-2006, 08:24 PM
JustABigKid
I just received the pdf for the updated 85" Yak manual from Rezagh. It it a very professional looking manual, with lots of pictures and detailed construction info. Very nice
Old 04-04-2006, 08:58 AM
Rezagh
My Feedback: (73)
Fred,
I have sent you the manual 2 times now and both have bounced back. Please fix your email address problem or give me another email address.
Thank you,
Reza
Rezagh is offline
Old 04-04-2006, 09:48 AM
jdavera
Reza,
Could you please send me one copy to my e-mail,
[email protected]
John
jdavera is offline
Old 04-04-2006, 10:09 AM
discusmike
I'm in the process of building my 85" yak now,would love to have a copy of the updated manuel,my addy is; [email protected] appreciate any help.
discusmike is offline
Old 04-04-2006, 10:16 AM
Rezagh
My Feedback: (73)
Manual emailed.
Thank you
Rezagh is offline
Old 04-04-2006, 11:46 AM
FredRasener
Reza,
Sorry about my E-mail being out of date. I regret the inconvenience.
My email is now correct. Please try again.
Thanks Fred
Old 04-04-2006, 11:58 AM
Rezagh
My Feedback: (73)
Fred,
It bounced back again with following message:
This message was created automatically by mail delivery software.
A message that you sent could not be delivered to one or more of its
recipients. This is a permanent error. The following address(es) failed:
[email protected]
SMTP error from remote mail server after RCPT TO:<[email protected]>:
host xmxpita.excite.com [208.45.133.107]: 550 <[email protected]>:
Recipient address rejected: User unknown in virtual alias table
------ This is a copy of the message, including all the headers. ------
------ The body of the message is 2174525 characters long; only the first
------ 106496 or so are included here.
Rezagh is offline
Old 04-04-2006, 12:47 PM
Rezagh
My Feedback: (73)
Hi All,
For now please go to my website to download QQ-Yak 85" manual.
www.gholamipour.com/QQ_Manual
We will soon update Quique's website.
Thank you,
Reza
Rezagh is offline
Old 04-04-2006, 03:35 PM
griffin
Reza,
I got the new manual from your site. Thanks.
I have a question about the anti-rotation pins. If I leave 10.5mm from the hole in the pin to the root rib, the pin is too short to go into the hole in the second rib. Also there are a number of posts about guys rotating the front pin vertical to make it easier to get in and out. Is there a specific reason for it to be horizontal?
griffin
griffin is offline
Old 04-04-2006, 03:52 PM
Rezagh
My Feedback: (73)
Hi griffin,
The reason for horizontal and vertical is for you to be able to insert the pin clip. See rear pin is vertial because you will have a hard time inserting the pin if you install it horizontally, it's right next to the former. Trust me it's a lot easier to have it that way plus chances that both pin clips come out one in Horizontal and one vertical is almost close to 0.
As far as measurment, I did exactly 10.5 to center of the hole and pin comes in perfectly. I can insert my washer and then the clip. Now if you do shorter than 10.5 you will have a hard time inserting the clip(that can be really a problem). Longer than 10.5mm you can compensate by adding another washer on top of the other one to keep the clip snug fit to the washer/oring setup. I really don't know why someone would rotate them. I know that the rear pin is next to that thin former and from one side you can't insert it and from the other side, part of the clip would hit the former. If you haven't done yours yet, please do follow the instruction or test it with inserting the pins alone into the fuse holes and see if you can easily insert the pin clip in vice-versa set up.
Thank you for your question,
Reza
P.S Sorry I missed your point. How long is your pin. If you leave 10.5mm your pin should still go into the second rib not very much but still will go in. Give me the length of your pin and I will check it with the ones that I have. All 4 of them are like that? It's got to go in the second rib if it doesn't DO NOT glue them.
Rezagh is offline
Old 04-04-2006, 05:00 PM
griffin
The pins are 92mm long total. The hole is 85mm from the end of the pin. The second rib is 70mm away from the face of the root rib, so the pin just barely touches it when I allow the 10.5mm.
griffin
griffin is offline
Old 04-04-2006, 05:06 PM
Rezagh
My Feedback: (73)
griffin,
Let me get back with you as soon as I get home. I need to check mine before I make any comments. As long as it does touch the second rib you should be fine. I'll get back with you, Thank you
Rezagh is offline
Old 04-04-2006, 10:10 PM
Rezagh
My Feedback: (73)
griffin,
I just measured mine. My pin is 2 mm shorter than yours and yet it does go inside the second rib. You should be fine. See the pin shouldn't go like 3mm inside as long as it goes in within the thickness of second rib, you are fine. Make sure do couple of rounds of super thin CA first and after that hit it with epoxy and micro ballons just like the picture. Follow gluing steps in the manual and make sure you get the right measurement and you will be fine. Don't be scared it's not that bad at all. Once you do the first one, the rest get easier. Let me know if you needed any help.
Thank you,
Reza
Rezagh is offline
Old 04-04-2006, 11:40 PM
griffin
Reza,
I realize now I should have asked my question in the forum. Sorry about that ...
I hear what your saying about the pin but mine doesn't go in the hole at all, it just makes it to the rib and that's it. Maybe my second rib is a little further away from the root rib than yours. Anyway, I've made some washers out of some 3/32" ply and plan to glue them to the second rib to help hold the pin. Think that'll be ok?
I've had good luck with gorilla glue in the past. I used it on my hinges on this one and plan to use it on these pins too. Do you see any problem with that?
griffin,
griffin is offline
Old 04-05-2006, 05:30 AM
discusmike
Thanks for the manual,its great,definently a big help for me.
Old 04-05-2006, 09:06 AM
Rezagh
My Feedback: (73)
griffin,
If yours doesn't make it to second rib, I need to check with Quique on that. I like your idea of gluing the ply-wood washers but wait until I double check with Quique. As far as gorilla glue goes I've had only one experience with it when I did my hinges. I think it's ok but to be perfectly honest I like the 30 minute epoxy and micro ballons better, if you feel comfortable with the gorilla glue go head and use it. I hope I can get a hold of Quique, I know they are getting ready for Toledo show. I'll get back with you.
Thank you,
Reza
Rezagh is offline
Old 04-05-2006, 09:39 AM
Rezagh
My Feedback: (73)
griffin,
Quique said the same thing li-poly washers with at least 1/8" thickness would do the job. I would use 30min-epoxy and micro balloons for that application. .
Please let me know if I could be at any help.
Thank you,
Reza
Rezagh is offline
Old 04-05-2006, 03:20 PM
griffin
OK, I'll do it.
Thanks a lot for your help!
griffin,
griffin is offline
