Yak 85" and MVVS 58
Old 05-17-2006, 09:35 AM
danilo
Default Yak 85" and MVVS 58
Hallo everyone,
someone tried this engine on that plane?
Bye
Danilo
danilo is offline
Old 05-17-2006, 09:37 AM
Rezagh
My Feedback: (73)
Default RE: Yak 85" and MVVS 58
Hi Danilo,
It's a good combo. You are ok to use it.
Thank you,
Reza
Quique's Aircraft Support
Rezagh is offline
Old 05-17-2006, 09:48 AM
danilo
What do you think about the prop.
I am oriented to install carbon fiber 22x10 3 blade.
danilo is offline
Old 05-17-2006, 09:53 AM
Rezagh
My Feedback: (73)
danilo,
Prop is mostly an engine spec related item. If your engine does take 3bladed 22x10, you should have plenty of power to fly the plane with it. To be more clear, plane will fly fine with 22x10 (3 bladed) prop as long as its withing the allowed props for that engine which I think it is.
Thank you and good luck,
Reza
Rezagh is offline
