GenII Yak 102 Landing Gear
Old 07-27-2006, 09:09 AM
Rezagh
My Feedback: (73)
Default GenII Yak 102 Landing Gear
Hi Guys,
I have put the new landing gear on our Yak 102" through series of tough tests and it has passed every single of them. I even did harrier landing yesterday and did not chip the prop. It just flexed enough to absorb the shock! I was running a 27x10 Mejzlik and prop didn't get near touching the ground. For those of you with GenII, do not hesitate to use the stock gear. It works really Awesome. I don't recommend harrier landings in general but for the sake of experiment I tried it and passed test wonderfully.
Thank you,
Reza
Quique's Aircraft Support
Rezagh is offline
Old 07-27-2006, 04:30 PM
kredge540
Default RE: GenII Yak 102 Landing Gear
Reza
Is there enough prop clearence on the Gen II to use a 28x10? On the Gen I I am useing a 27x10 but only because there is not enough ground clearence for a 28x10.
Kevin.
kredge540 is offline
Old 07-27-2006, 04:36 PM
Rezagh
My Feedback: (73)
Kevin,
Yes, you can use 28x10 on GenII landing gear. I don't see any problem with that. Landing gear doesn't flex as much but still does absorb the impact. I was expecting to chip my prop when I dropped the plane from almost 1 foot off the ground but I didn't. I feel no one should have any problem with the new gear at least I hope so.
Thank you,
Reza
Rezagh is offline
Old 10-16-2006, 06:33 PM
JET-A
Ive broke about three props already on gen1 gear are the gen 2 avail for purchase??
thanks
JET-A is offline
Old 10-16-2006, 07:56 PM
Rezagh
My Feedback: (73)
Unfortunately, GenII landing is wider at base and won't fit the Gen I fuse!
Thank you,
Reza
Rezagh is offline
Old 10-31-2006, 05:35 PM
Iflyit
My Feedback: (512)
So what options are there for the gen 1 yaks? I am putting one together now and dont like the thought of a weak gear if it damages $50 props.
Iflyit is offline
Old 11-06-2006, 07:48 PM
Tricktrack
Iflyit,
I purchased the TNT metal gear for my Yak, 13" version and while it added a little weight, it did not change performance at all. I have a ton of clearence now.
Tricktrack is offline
Old 11-07-2006, 07:53 PM
JET-A
What did the gear cost ??
thanks
JET-A is offline
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
