Updates to Assembly Manuals
My Feedback: (73)
Dear All,
I will be anouncing any updates to our assembly manuals on this thread. It will always stay on top so you won't miss anything.
Regards,
Reza Gholamipour
Quique's Aircraft Support
Regards,
Reza Gholamipour
My Feedback: (73)
RE: Updates to Assembly Manuals
Update for QQ-Yak 102":
Our QQ-Yak 102" assembly manual is updated to show correct way of pull-pull installation. Please check www.qqaircraft.com in couple of hours.
Regards,
Reza Gh.
Regards,
Reza Gh.
My Feedback: (73)
Update for QQ-Yak 69":
I'd like to emphasize on the fact that you need to use minimum of 130 oz-in digital servos for this plane. Please do not use analog servos if you can and if you decide to use analog servos, make sure to use metal gear and minimum torque of 180 oz-in.
Reza
Reza
My Feedback: (73)
I'm not really sure what Quique wants to do about this but I suspect we will be using the same manual since changes are not that significant and won't affect the assembly.
My Feedback: (62)
NJ
So does the Gen III have all the same hardware inclusions with it, like the titanium pushrods, ball links, cf tubes, sfg's, CF rudder horn, composite landing gear, pull pull hardware, wing bags and canopy cover?
Bob
Bob
How about an update for the elevator cables in the 49" Yak. Step 3 and 7 both state tha the upper and lower slot are for the right servo arm connection. Wich one is it?
Adam
Adam
My Feedback: (36)
Just started to assemble my Pitts Python and "no bolts to install the landing gear".. What size are the installed blind nuts ? Hope they are not metric, as I will not be able to get those at the local hardware store !!
My Feedback: (17)
KY
Hey Reaza the manual for the Gen3 and the gen4 are all Gen2 manuals and i cant tell the info i need on them. Is this mistake and do you have a manual that depicts the gen 4 in and out?
My Feedback: (73)
G4 and G3 are the same in assembly with G2. Quique didn't feel the need of new assembly manual as construction is the same. Do you have a G4 and something looks different than manual? or you just wanted to see the pictures?
Let me know.
Reza
Let me know.
Reza
My Feedback: (17)
KY
Im going to get a G4 if the current plans fall through and it doesnt look good for the current plans.
Im mainly interested in the canister tunnel on the g4 and a few other things like canopy instalation. I just want to make an informed decision.
My buddy Meanrudder is in my ear every night on the phone telling me to get a G4 mobster style lol he should be on the payroll.
My Feedback: (71)
I have the Gen II manual for my G4 100cc yak. Manual says to cross the pull-pull cable and use Sullivan Gold-n-rod 504 over the cables to block RF. What change/update is there about the rudder pull-pull set up not noted on the manual that came with the plane? I just got the plane 10 days ago.
My Feedback: (73)
Pull-pull is the same as G2. If you are flying 2.4 then you won't need the cover over the cable otherwise everything else stays the same including crossing the cable
ORIGINAL: kmtranmd
My Feedback: (26)
KY
ORIGINAL: Rezagh
Dear All,
Regards,
Reza Gholamipour
Dear All,
Regards,
Reza Gholamipour
is there any update for instalation of the tail wheel on the yak54 86"? the new tail wheel come with a spring and not a "piano wire" as stated on the manual. also there would be nice to had photos of the ruder pull pull instlation looking at both sides , just as a help, i had too look on other threads and forum to be 100% sure i'm doing it right.
Thanks and great arf so far
