86" Progress Reports
Old 11-16-2007, 11:32 AM
  #376
BaldEagel
BaldEagel's Avatar
Default RE: 86" Progress Reports
ORIGINAL: octanehuffer
What is a cowl binder? The ail servo looks right but when the pic was taken was the aileron neutral? I see the servo horn is not 90 degrees. Regardless, I see no problems with the pushrod angle.
Adam
Except with the pushrod not being at right angles to the hinge and the servo arm not being at right angles to the servo you have introduced differential to the movement, greater arc one side than the other, if the other aileron set up is the same you may have to mix out the differential in the TX, but if you are the same standard of flyer that I am you will not notice the difference. LOL see if you get axial rolls if not then the differential needs adjusting.
Mike
BaldEagel is offline
Old 11-16-2007, 01:43 PM
  #377
w4sm
w4sm's Avatar
The best method to use would be to tape a piece of paper to the fuse and make sure the paper is big enough to cover the item you want t cut out. Then cut out the area of the paper and then slide the cowl under the paper. Trace the outline to the cowl and remove the paper. I will post some pics of the process.
Adam
I use that technique to line up the cowl mounting holes just as you have shown, but I was hoping someone would have drawn and saved a template for the DA-50R cutouts and the associated cooling cutouts on the bottom of the cowl. The template would be taped to the bottom of the cowl and used to Dremel out the openings. The cutouts shown at the very beginning of this thread from several years ago (by Plasticman as I recall), are particularly nice.
w4sm is offline
Old 11-16-2007, 09:16 PM
  #378
cyoung450
My Feedback: (60)
On the aileron linkage, the angle is fine it is that way because of the large control arm on the servo, as it travels you will see that it does not bind and the angles are correct. I was impressed with this myself because someone thought it through in the design, I have had it look the other way on some other planes of mine and it does not seem to be as linear as the QQ. I have had no differential problems at all, this thing rolls like it is on a rail.
Just my two cents though,
Conrad
cyoung450 is offline
Old 11-16-2007, 09:19 PM
  #379
octanehuffer
octanehuffer's Avatar
Yup. Mine too. I actually did the pattern set up test and the was no differential what so ever.
octanehuffer is offline
Old 11-20-2007, 01:20 PM
  #380
w4sm
w4sm's Avatar
Is it necessary to make the cutouts in the bottom covering around the cannister muffler on the 86" for cooling? Most (but not all) of the photos seem to show this, although I haven't found it described in the assembly manual (unless I missed it). It's easy enough to do, but does any of the exhaust residue then find its way inside this area? If so then some fuel proofing may be required. Thanks.
w4sm is offline
Old 11-21-2007, 03:30 PM
  #381
Rezagh
My Feedback: (73)
Off topic question guys,
Can someone give me the exact measurement for the 86" length with or without spinner is fine. I actually prefer w/o spinner. I am not home to measure myself and would like to provide someone who wants to know whether this fits in his car or not. I am kinda sure it will fit in a Toyota Matrix but measurement would be great.
Thanks guys,
Reza
Rezagh is offline
Old 11-21-2007, 04:08 PM
  #382
EMVIN
76" without the spinner.
....EMVIN....
EMVIN is offline
Old 11-21-2007, 04:10 PM
  #383
ultimate65
My Feedback: (116)
Thanks very much
ultimate65 is offline
Old 12-20-2007, 09:16 AM
  #384
cyoung450
My Feedback: (60)
Well I have put this plane in 3 times, broke motor box and landing gear all three times, this plane flies great but is a bit on the fragile side IMHO. Anyway LOVE THE PLANE best flying plane I have ever owned.
Just wanted to let everyone know that BAD BRAD Graphics is doing a graphics kit now, just finished putting mine on. I have the big logos for the wings and sides that I have not applied yet but here are some pics of the current setup. This is the second fuse, that has been repaired once....
Brad's website is http://www.badbradgraphics.com he is a real good guy and will do custom stuff, and he has the best prices around.
Keep it low.....
Conrad
ID:	829917   Click image for larger version
ID:	829918   Click image for larger version
ID:	829919   Click image for larger version
ID:	829920   Click image for larger version
Old 12-27-2007, 10:34 PM
  #385
zope_pope
zope_pope's Avatar
Thats really good looking. My yak looks so plain!
zope_pope is offline
Old 12-28-2007, 03:24 AM
  #386
crankpin
My Feedback: (12)
Adam
Octanehuffer & Bald Eagle - Thanks for the answer's on the pushrod angle, aileron, etc. I set this up exactly like the instructions on the 86". JR8611A servos, AirWild arms, control horn mounted as called for. This is how the angle came in. I believe without looking out in the shop right now, full aileron deflection would put the pushrod at 90 degrees to the surface?
The Yak is back on the workbench after involving myself in some senior pattern planes, etc. I am setting up the rudder servo and cables now. I asked for and they sent me a new aluminum gear.
Vince
Hobe Sound, FL
crankpin is offline
Old 02-28-2009, 07:29 PM
  #387
tailspins
My Feedback: (7)
tailspins's Avatar
is this thread dead?
I was enjoying it and learning alot of information.
tailspins is offline
Old 02-28-2009, 07:37 PM
  #388
BaldEagel
BaldEagel's Avatar
Old threads never die they just fade away.
Mike
Old 02-28-2009, 09:19 PM
  #389
tailspins
My Feedback: (7)
tailspins's Avatar
Mke,
I am just finishing up my Yak 86er. I really like the yak series and thought this would be a great project for getting back into gas after about 5 years of doing glow and electric. I really do miss the sound of a gas engine and I was trying to scale back on the size of planes and so on.
I am just waiting for the power box to come and all will be finished. Who knows what the weather will bring in South East Iowa so I might get a chance to get in a flight soon.
I had the same gear issue with the paint chipping on my QQ 73 inch Yak and when I talked to QQ he sounded like my gear was the only one with this problem. After reading this thread I find that this happened to alot of people. If it fails I wll get a replacement from TNT gear.
Thanks for posting!
John
AMA 1121
Old 03-01-2009, 05:09 AM
  #390
crankpin
My Feedback: (12)
I went to the QQ Aircraft site yesterday, sez they are out of business from the original start-up, etc. All remaining kits, etc., have been taken over by Chief Aircraft.
I think too much competition from other company's, some folks out of work, makes a strong money crunch. Usually if someone want's to make a living from a hobby or sport, where disposable income is used at the end user, buyer level, they better have sales and money, plenty of it.
QQ Aircraft put our a very nice product, but as soon as you have something good, it get's copied, over and over again, by folk's thinking they can do it too. It would be nice to see these guy's surface again, they were first class.
Crank
crankpin is offline
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
