New Somenized Yak 102", Gen III
#101
RE: New Somenized Yak 102", Gen III
Has anyone tried the DA 85 yet, or is it a bit too light for C of G?
cheers
Robin
Also can anyone give me a measurement from Cowl,not spinner, to rear of rudder. Its got to fit as well!!!
cheers
Robin
#103
Hello,
I started a little build threat on my blog:
[link]http://davidlepore.blogspot.com[/link]
I planned to try the 3W-85 XI CS as engine for the Yak, but in the end I had to go with the DA-100, since we have noise restrictions at our field and I couldn't fit a proper muffler in the tunnel without having to do major modifications.
Perhaps this could be modified in the GEN 4 Yak.....
Greetings,
David
Greetings,
David
#105
No, the DA-85 also needs at least 70mm in diameter in case of a tuned pipe and 80mm in case of a canister. The tunnel is maximum 60mm....
#107
My Feedback: (73)
The 102" is designed for DA100. It is not as easily balanced with DA85 as the Python! We won't be showing the 102 with DA85 but ........
#108
Your period button seems to have something wrong with it. Or you are hinting at something. Please PM me with a continuation. I need to order a Python or 102" soon, but if there is an alternative please let me know. thank you.
Adam
Adam
#111
I am looking for the quietest possible set up for my DA 100. I already have the cans but I heard 3 blade props are quieter. Are they much quieter? Does vertical performance, like out of a hover, suffer much? And what size and manufacturer is favored? We are getting noise complaints at my club specifically targeting large gas planes flying IMAC patterns.
#112
My Feedback: (73)
Eric,
What prop are you using now? Size and brand.
3 bladed such as 25x12 Mejzlik will make very quiet. However 26x12 two bladed Mejzlik with Can set up should be very quiet as well.
Pull outs will get a little weaker with 25x12 but you should still be fine. It's a totally different feel on the 3 bladed props. They are good for IMAC for sure, it will be OK with GenIII for 3D as it is not a heavy plane.
Hope this helps,
Reza
Hope this helps,
Reza
#114
I have had my gen.III yak 102 for just over 1 year now. I went flying today and to my surprise my canopy is now warped. Has anyone else had this problem and is there a fix for it.
It is warped enough to have cracked the plastic of the canopy.
Haggiej
Haggiej
