New Somenized Yak 102", Gen III
My Feedback: (73)
Dear All,
New Somenized (TM) Yak-54, 102" Gen III will be available by Mid June. Plane will have the folowing changes:
1. New 120" QS scheme, meaning just like the new 120" QS scheme.
2. Foam free tech.
3. SFG clear color
4. Plug and run canisters
5. New canopy structure for longer life.
6 A thin foam has been added to the back of the canopy to reduce noise.
Regards,
Reza Gholamipour
Quique's Aircraft Support
2. Foam free tech.
3. SFG clear color
Regards,
Reza Gholamipour
NJ
RE: New Somenized Yak 102", Gen III
Hey Bob,
This batch first of the G III 102"ers is the new Brio scheme. I'm not sure if they will do white ones in the future, I'm sure Reza will answer that. Mine will be here this week, your pretty close to me you are more than welcome to check it out anytime, it's a great looking and flying plane.
Lee
Lee
My Feedback: (62)
NJ
What is the "Brio" scheme, and how is it different than the previous colors?
Are you saying that you have one on order and it will be here for sure this week?
I called today and was told the next batch will be here soon and had to leave my name on a call list.
My Feedback: (62)
NJ
Mine arrived on 07/03/07 also. I was told the shipping company would give a call to schedule delivery, but there was no call.
It's a good thing I was home, and it was late evening when it got there. Wonder what would have happened if I wasn't home?
No biggie.
This thing is top shelf in workmanship, and a beautiful plane. Everything was as advertised and straight as an arrow.
I could not have done as nice a job as the plane I received.
One suggestion for packaging for clumsy people like me. I had to unpack it alone as there was no one around to help me.
When I pulled the fuse out of the bag, the canopy fell of and hit the floor []
Put a nice sized break in the back of the canopy which I'll have to patch up somehow. No matter what I wind up doing, it will show
and be ugly.
Anyway, after I finish with the 80" OMP Edge profile kit, this baby is next.
Raining here today on the 4th [&o]
No biggie.
and be ugly.
NJ
Here are a couple pics. All servos and linkage is installed know also. I'm held up right now because I need to get to the hobby shop for some things. I don't want to mount anything until the motor is mounted so I can figure out where to put the power box ect... I will be ready to fly tomorrow.
Lee
Lee
Moderator
My Feedback: (58)
Reza, I was doing a visual check when I noticed that the left landing gear metal brace has the tapped holes only partially through the metal, whereas the right brace has the tapped holes all the way through. Is this normal? I guess not. In that case, what can be done to rectify it?
The instruction manual in the box is for the Gen 2 Yak 102". Has there been a packing error?
My Feedback: (17)
ID
I'm thinking about this plane. Website says it's still not available. Yet it looks like people are getting them?!?!?!? Is it available to the common man?
Barry
Barry
NJ
Give QQ Aircraft a call. They have been very busy and I don't think they have had a chance to update the website. I know they send everything they have pre-ordered by people out first but they should still have plenty planes left.
Lee
Lee
My Feedback: (73)
Hi Barry,
Our webmaster is not feeling good, he's been a little sick and we wish him soon recovery. Anyways, yes they are available. Get it before you have to wait for the next shipment
Reza
Reza
KY
Reza, have you got yours yet? we need a build thread with pics. i don't have one on order yet and am still not sure what i will build next. i do know that the QQ yaks rock as always and it is on my short list.
randy
randy
My Feedback: (73)
Lee,
Picture looks great!
Randy,
Mine is still in the box. I will open it up and do detailed pics of everything next week. I'm not sure if time would allow a build thread, especially that GenII and GenIII are very close almost identical except that GenIII has the ready to run canister that makes it even easier.
Bobzilla,
Are we out of stock on these items?
Regards,
Reza
Randy,
Bobzilla,
Regards,
Reza
Moderator
My Feedback: (58)
Reza, in the bag labelled "cowl mounting parts" there are four wooden blocks as per attached pic. What are these used for? I can't find any description for these in the manual.
Also, there should be six cowl grommets instead of the four provided. Two additional needed for the standoff holes
My Feedback: (73)
Hi rajul:
Those are for engine stand offs but we don't use them. On the grommets, we only use 4 and the other two in the middle of the cowl I personally use wood screws
Thank you,
Reza.
Thank you,
Reza.
ORIGINAL: rajul
Moderator
My Feedback: (58)
Pg 38 of the manual mentions that grommets are to be used for the standoff holes.
The rudder hardware pack seems to be short of two 4-40 ball links (four ball links are in the pack) and two 1.5" titanium rods. These are needed for dual rudder servos. Again, in step 6 in pg 25 of the manual, it says these items are provided, but they're not in the rudder hardware pack.
Another discrepancy found is that in page 22 of the manual, step 4, it says to use 2" titanium rods. However, in the elevator hardware pack, the two titanium rods provided are 1.5" in length.
My CF double arm is also cracked and delaminated on one end, but I'll be replacing it with a swb offset arm. I've also replaced the stock fuel tank with a 32oz dubro tank.
My Feedback: (73)
Please email me what's missing and I will have Molly send them to you. The titanium rods for rudder should be provided as mentioned in the manual. We can also send you a CF arm for rudder if you want another one. It should not be as pictured.
Thank you,
Reza
Thank you,
Reza
ORIGINAL: rajul
Moderator
My Feedback: (58)
Reza, all help is well appreciated! There's a tristock at the bottom of the firewall which I think will interfere with the installation of two blind nuts. It will be much easier to remove the tristock, installl the blind nuts, then cut and reglue the tristock between the nuts. I would like to check with you if a heatgun will be able to soften the glue enough to remove the tristock? I will request for a spare tristock too just in case I mess this one up during the removal process. Thanks
