Yak 86" Electronic Placement
Heya Guys with 86" Yaks.
Was just wanting to know where you guys placed all your electronics in the fuse.
This is where my Receiver Packs will go. Does it look like a good enough location, and think it will ballance there? Should it be further forward or more rear.
I also have another lithium ion for the ignition with reg, should that go on the nose?
Thanks in advance you guys
RE: Yak 86" Electronic Placement
I have my stuff under the rudder servo tray. Two batt packs, two regs, two switches. Reciever is on the front of the servo tray former. Just leave you electronics loose and finish the rest of the plane first. Then try to balance it. If it needs adjusting, move things around.
Adam
Adam
